Multisim and Ultiboard
ultiboard export DXF error
When using version 12 to export a DXF (2D), the resultant file is blank. This worked fine in v11. Has anyone had an issue with this yet?
(3,573 Views)
I created DXF file and was able to open it in Ultiboard. I also tried an online viewer. Attached you will find the DXF file.
Are you still having issues with this? We may need to test your design file.
Fernando D.
(3,537 Views)
Fernando,
No,I found a simple solution.The inital problem was that all DXF files exported from Ultiboard were blank. There has been a CAR for issues concerninf DXF exports in revision 12, so I was told.
I found that any free text labels placed either on a copper layer or silk screen that had a line break would cause my exported file to be blank. Removing the line breaks (CR) solved this problem.
Here is another thread with more information...http://forums.ni.com/t5/Circuit-Design-Suite-Multisim/Ultiboard-v12-DXF-Problem-bottom-side-graphics...
(3,534 Views)
Thanks for the update!
Fernando D.
(3,528 Views)
