Multisim and Ultiboard
ultiboard symbol connection
What is the meaning of the four triangles surrounding the hole on the left?  it is from a layer on the multilayer design. See the attached figure.
(4,649 Views)
The triangles you see are not covered by copper. Ultiboard makes (on request) "thermal optimization" of pads which are part of a copper plane. If the pads were directly connected to the copper plane, a lot of heat would be transferred to the copper plane when soldering, thus prolonging the necessary solder time or, in other words, making the solder connection not reliable when using a standard soldering process.
So the pads are connected via short tracks to the copper plane. These will transfer less heat when soldering, so the pad can be soldered with a standard process.
Since thermal conduction and electrical conduction are closely related, also the electrical conduction is reduced - or the resistance between pad and copper plane is increased. So you have to find a compromise between reducing heat transfer and increasing resistance. Ultiboard has several options for themal optimization of pads.
(4,636 Views)
Thanks for the reply.  You said: So the pads are connected via short tracks to the copper plane.
Can I assume there is a good electrical connection to the power plane after soldering the lead that passes through the hole for this arrangement.
Or do I have to place a via to the power plane and make other traces connected to the via??
(4,628 Views)
Accepted by topic author HBNI
All I can say is that most, if not all, layout systems use the "thermal optimization" for pads connected to a copper plane. The electrical connection seems good enough - we are using this technique with an older system and Ultiboard for decades and never had any problems with power supply pins up to several amps rating.
(4,616 Views)
Thank you.
(4,612 Views)
