Multisim and Ultiboard
unable to getthrough the steps adding new component (OPAMP)
I am using multisim13.0 and wanted to add the opamp OPA378 http://www.ti.com/lit/ds/sbos417d/sbos417d.pdf as it was not found in the multisim13 component list.
followed this tutorial http://www.ni.com/white-paper/3173/en/  but was not able to get anything in the filter to add row as metioned in the tutorial as shown below.
The footprint is SC70 DCK 5 as shown in the page22 of datasheet.
Can someone help me out with adding the component.
(6,439 Views)
Hi PatanGova,
Have a look at this knowledge base:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019VDcSAM&l=en-US
In the filter dialog, click on Add Row, the * is a wild card and it helps searching for specific string.  In the attached screen shot, I added two rows and I am search for any part with 5 pins and the footprint name contains "SC70".
Tien P.
(6,431 Views)
Hello Tien P,
I searched the footprint with name "SC70" and got the different ones(as shown in attached image) as compared to the one you showed in your image(as analog Devices,etc.,).Also I don't get anything in the footprint.
can I know to add the correct footprint ?
thanks.
(6,421 Views)
Hi PatanGava,
In the filter click on Add row, click in the cell below Column and select Footprint, now in the Value column, type *SC70*.  Click Add row again, on the second row select Pin Count and 5 for value.  Your screen should look like this:
When cannot find a footprint in the Master database, you can add one by highlight the User or Corporate database  the click the Add button, you will get a pop up window where you can define your own footprint.
Tien P.
(6,416 Views)
Hi Tien P,
I tried as shownin the attached image by selecting IPC-7351SC70-DCK-5 but when I was about to add .sym as mentioned here https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH5fCAG&l=en-US I was unable to find the respective .sym file in the OPA378 spice model http://www.ti.com/product/opa378.Do I need to convert the files in OPA378 to .sym or is there any other method.
Thanks.
(6,393 Views)
