Multisim and Ultiboard
usb simulation
please, can I simulate USB port on Multisim ?
thank you
(7,098 Views)
For schematic capture purposes, there are some USB connectors in the Multisim Master Database, however, you can't use these for simulation. USB requires the use of a protocol and this is something not supported in a SPICE simulator. If you tell us more about your project we may be able to provide suggestions.
Best,
Fernando D.
(7,078 Views)
Hi, thank you for your reply
my project is simple I want just part of numeration at low speed transfer (HID protocol), may be I can control some leds later by microcontroller
thanks
(7,067 Views)
Hi, Fernando D.
have you an Idea about my project ?
greeting
(7,054 Views)
As mentioned before, Multisim does not support the simulation of USB ports. Perhaps you could program the protocol using a microcontroller. In Multisim look for the MCU group in the Master Database. You will find some microcontrollers that can be programmed in C or assembly. There are a couple of examples in File>>Open Samples>>MCU.
Best,
Fernando D.
(7,041 Views)
