Multisim and Ultiboard
using labview cosimulation, how to control PWM duty cycle in multisim
I am new to using Multisim with LabVIEW using cosimulation. I want to ask if there is a PWM component in Multisim that can have its duty cycle be controlled using LabVIEW? I have an algorithm in LabVIEW that outputs duty cycle values from 0 to 1, representing duty cycle percentages.
How do I control the PWM duty cycle in Multisim using LabVIEW cosimulation?
Many thanks,
SPECTRE
(6,573 Views)
Accepted by topic author SPECTRE
Hi Spectre,
In Multisim, search for the parts base on functionality, there are some PWM models in the database.  Have a look at this knowledge base  if you don't know how to search for parts:
http://digital.ni.com/public.nsf/allkb/7309A5CABC677296862577ED006EC99E
Aslo, have a look at this knowledgebase:
http://digital.ni.com/public.nsf/allkb/EF391C48CF71AE4F862571B900644F84
This article shows how you can get Mutlisim and LabVIEW to co-simiualte:
http://www.ni.com/white-paper/13663/en
I hope this helps
Tien P.
(6,559 Views)
Can You make me understand this? please
@SPECTRE
(3,892 Views)
Here is a screen shot of the basic PWM function.  In order to control the PWM duty cycle you input a voltage from 0 to 1.0 proportional to the desired duty cycle.
The PWM frequency and output voltage amplitude and rise/fall time are all settings of the PWM function.
(3,884 Views)
Thank Dear,
(3,874 Views)
