Multisim and Ultiboard
variable power supply not working in virtual elvis
When i make a virtual elvis 3d schematic i cannot get any output from the variable power source, i have played with it alot and still no output. please help.
(4,016 Views)
Hello jigster213,
First of all, make sure you configure the desired parameters:
  • Double-click on “Variable Power Supplies”. The properties dialog box for the NI ELVIS power supply appears.
  • Click on the Value tab and enter the desired parameters. Note that you can use control keys (i.e. P and N) to increase/decrease the values.
  • Click OK to close the properties dialog box.
Run a simple test using the Multimeter:
  • Positive terminal to SUPPLY + and negative terminal to GROUND.
  • Run the simulation; the initial value is 0. Press Shift+P to increase this value, to decrease the output press P.
Let me know how it works.
Fernando D.
NI EWB Group
Fernando D.
(3,996 Views)
Thank you for your time to help me out,
I got it to work using the shift+P and shift+n hotkeys. A suggestion I have is to remove the shift restraint for the GUI interface P and N buttons that appear on the screen after you highlight variable power supply, as it is non-intuitive for a user to know you must hold shift then press GUI buttons as well. I suggest coding those visual buttons to alias SHIFT+P and SHIFT+N operations when you click on them for ease of user interface.
(3,966 Views)
