Multisim and Ultiboard
virtual elvis not connected error
I'm trying to make a simple circuit using virtual elvis with multisim.   I connect the circuit to the elvis +5V and ground.   When I switch to the 3D elvis breadboard mode, I connect all the parts and wires, but the connectivity test keeps telling me that
Multisim  -  2007-03-03 13:43:08
---Design Rule Check---
---0 Design Rule Errors Found---
---Connectivity Check---
Connectivity Error : For Net 0, Pin Ground2 of component ELVIS10 is not connected.
Connectivity Error : For Net 1, Pin 5V2 of component ELVIS10 is not connected.
---2 Connectivity Errors Found---
I can't figure out why.
(I moved this post from the NI-ELVIS board)
(3,606 Views)
Do you have a sample file we can take a look at?
Remember that in a ELVIS Schematic you have to connect power supply and ground pins...  if you look at the schematic (not the 3D breadboard) to the lower left corner you will see a connector that says GND and +5V (among other ones), if you have those connected in the schematic... when you transfer to 3D breadboard you need to connect those pins to your circuit as well. I'm pretty sure this is what's missing.
If not, then attach a zip file with your circuit file.
Nestor
(3,585 Views)
