Multisim and Ultiboard
voltage dividers
How could I use a voltage divider to answer this question?
In the manufacturing of car batteries, should the batteries have a very low internal resistance or a very high internal resistance?
(1,509 Views)
Can you explain what this generic question has to do with voltage dividers?
(1,480 Views)
A low internal resistance is preferable but how could you illustrate this using a voltage divider?
(1,470 Views)
Привет! В графическом виде, с использованием параметрического анализа, Вас устроит?
(1,425 Views)
(1,418 Views)
Hi libby6295,
Let:
Vbatt = the battery's terminal voltage when there is no load connected (the battery's open-circuit voltage)
Rbint = the battery's internal resistance
Rload = the load (resistance)
Vload = the battery's terminal voltage when the load is connected
When the load is connected the circuit is shown in the image below
By voltage divider formula:
             Rload
Vload = ─────────────── Vbatt
         Rload + Rbint
From the above formula we can see that for a particular value of Rload,
  • if Rbint is small, the denominator is small so the battery's terminal voltage (Vload) tends to be high
  • if Rbint is large, the denominator is large so the battery's terminal voltage (Vload) tends to drop
Hence for a voltage source such as battery, it is desirable to have a small internal resistance.
G. Goodwin
(1,392 Views)
