Multisim and Ultiboard
where is the problem and how to fix it?
i want to put the circuit in the pic into multisim software, but there is a problem when i try to run it. i wonder why it doesn't work and can anyone tell me how to fix this?thank u!! and if possible can u also tell me the method to set rbe of the BJT?
(1,867 Views)
Throw a file with the extension 'ms'
(1,855 Views)
(1,848 Views)
Hi, darling! I slightly corrected your circuit so that Q1 would not fly out, put R1
(1,815 Views)
thank u so so much for correcting the circuit. But i still have the question about how to set the number of rbe.
My teacher says if u set rbe of 3 BJT as the picture down there goes, there should be a perfect wave of Trigonometric Functions(sry for my poor english)
(1,811 Views)
Поскольку анимированные транзисторы создают плохую сходимость, меняем их на другие модели. Снимаем ограничения синусоиды путём установки в схему дополнительных резисторов
и проверяем, не нарушены-ли режимы транзисторов по мощности:
(1,789 Views)
Спасибо! i'll try this right now
(1,781 Views)
