Multisim and Ultiboard
with ultiroute 9 I have a round board. It autoroutes ouside the board. How can I stop that.
(6,180 Views)
Could you attach your design files for troubleshooting?
Fernando D.
(6,169 Views)
Fernando,
I'm not sure what you mean by design files. I am attaching the ms9 capture file. I transfer that to ultiboard, change to a 2.8 inch round board and auto place and autoroute. It gets 100% but runs way out of the round boundary.
(6,164 Views)
I was referring to the Ultiboard files (*.ewnet and *.ewprj). Please attach those files, it will be easier to troubleshoot the issue.
Fernando D.
(6,146 Views)
Here are the files.
Bob
(6,143 Views)
looks like only one file went. I'll try again. It won't let the extension go. I'm going to try to change the extennsion to .zip but of course you will have to change it back to .ewnet .   Well it wouldn't let me do that either. You have the ms9 file so you can generated the net.
Bob
(6,141 Views)
Thanks for the files Bob. I was able to reproduce the issue in version 9. After doing some research I found out that this was a known issue (ID: 266543) that was fixed in version 10.0.1. It seems that Ultiroute had a hard time routing circular boards. Unfortunately there is no patch v.9, you will need to manually fix the traces that are outside of the board outline.
Just to verify I opened your file in Ultiboard 13, deleted all the copper and ran the Autorouter. Here is the result:
Sorry for the inconvenience Bob.
Fernando D.
(6,137 Views)
