NASA LabVIEW User Group Community
Labview OPC Interface ?
I am trying to use Labview as an OPC client and want to communicate with an OPC server (both on same machine). I tried using DSC module/Bound Variables but no luck so far...i was able to create an I/O server, bound variable to that server and i see the values first time...but then it becomes to zero....couldn't figure out what is the reason...
Let me know if anybody has used Labview with OPC ?
Regards
Harjeet Singh
(7,560 Views)
Hello Harjeet,
I know we've already closed the loop on this.  For anyone else looking for help with OPC in LabVIEW, here are some resources.
Connect LabVIEW to Any PLC Using OPC - Video
http://zone.ni.com/wv/app/doc/p/id/wv-263
Connect LabVIEW to Any PLC Using OPC - White Paper
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0MPCAY&l=en-US
Connecting LabVIEW to an OPC Server Using Front Panel DataSocket
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2C7CAI&l=en-US
-Travis
(5,668 Views)
I done some OPC communications before. You can give me a call at 865-566-3195 and I might be able to help.
(5,668 Views)
