1.本站在 NI cRIO-9101嵌入式機箱 中,下面有一項是寫
它們(9101 和 9111)之間是差在哪裡??
2. 那CompactRIO的 NI cRIO-9014即時控制器 可以支援上面的 cRIO-9111 嗎??
3.之前有去詢問過技術人員,也看過這篇原文資料庫
Problem
I would like to use the NI CompactRIO Scan Mode on my CompactRIO. What hardware supports this and what software do I need?
CompactRIO Scan mode was introduced with Real-Time module 8.6. In addition, the controller must be running the VXWorks Operating System and the backplane must contain at least a two million gate FPGA.
To use scan mode on a one million gate FPGA, the FPGA module is required and must be installed. Creating a blank FPGA VI under the target and then compiling this will then allow scan mode to be used.
At this time, the Single-Board RIO (sbRIO) does not support the Scan Mode interface.
Software:
Real-Time Module 8.6+
Ni-RIO 3.0+ with Scan Mode Support installed on cRIO
Hardware:
Controllers: NI 9012, NI 9014, NI 9073, and NI 9074
Backplanes: NI 9103, NI 9104, NI 9073, and NI 9074
The NI 9101, NI 9102 and NI 9072 are one million gate FPGA backplanes and require the FPGA module to use scan mode.
所以此文的意思就是要有200萬的FPGA閘數才有支援Scan mode,而9101只有100萬的閘數沒辦法直接支援Scan mode,那問題就是 cRIO-9111 有支援Scan mode嗎?? 那它的閘數是多少??
已解決! 轉到解決方案。
在
03-10-2009
04:38 AM
- 上次修改時間
05-08-2024
03:26 PM
修改人
Content Cleaner
5 new cRIO-911x reconfigurable chassis based on the Virtex-5 family of FPGAs from Xilinx.
These new chassis provide a significant increase in both FPGA size and performance over existing CompactRIO chassis and do so at the same or lower price.
The Virtex-5 FPGA is the newest FPGA available from Xilinx and are not only the largest FPGAs to date in CompactRIO hardware,
but also provide design improvements such as 6-input look-up tables (versus 4 for Virtex-II and Spartan FPGAs) and more efficient routing tools.
These 5 new chassis are available in 4 and 8 slot versions and are completely compatible with the cRIO 9012/4 and cRIO 9022 controllers.
All 5 of these new chassis support the new scan mode ease of use programming.
上編輯的訊息
在
03-10-2009
04:50 AM
- 上次修改時間
05-08-2024
03:28 PM
修改人
Content Cleaner
Scan mode is supported by controllers running the VxWorks RTOS with at least 2M gate FPGAs because of the FPGA space requirements. Supported controllers are the NI 9012, NI 9014, NI 9073, and NI 9074. Supported backplanes without additional compilations, include the NI 9103, NI 9104, NI 9073, and NI 9074.
在 03-10-2009 09:42 PM
