NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
4130 Error -1074135024 occurred at IviDmm IVI Error Converter.vi
Dear Sir
   I use NI calexec 3.3.2 software calibration PXI4130. But softawre display Error message. How can solution this error?
 use Hardward:Fluke5700A ,HP3458A ,aux power 12V
 Error Message
Primary Error: (Hex 0xBFFA0010) Invalid value for parameter or property.
Secondary Error: (Hex 0xBFFC0004) Parameter 4 out of range, or error occurred while setting Parameter 4.
Elaboration: Resolution
Complete call chain:
     IviDmm Configure Measurement.vi
     cex_Instr_IVI_Dmm_Configure.vi
     cex_Instr_DMM_Configure.vi
     Verify_NI 4130_Voltage Configure Std.vi
     Verify_NI 4130_Voltage Prog Accuracy.vi
at step Verify Voltage Programming Accuracy.ProxyCaller
Possible reason(s):
IVI:  (Hex 0xBFFA0010) Invalid value for parameter or property.
0 積分
1 條訊息(共 1 條)
4,039 檢視
