請問我用sbrio-9636 16bit AI
我的輸入電壓範圍在-2~+2 V,我要如何完整利用16bit在此範圍?
我在FPGA FXP Datatype = 整數4bit 小數 14bit,
這樣就可以了嗎?
若設成整數32bit 小數 32bit會如何分配?
在 05-30-2013 04:33 AM
http://www.ni.com/pdf/manuals/373378c.pdf
page 49, 可以看到 Input range ............................................. ±10 V, ±5 V, ±2 V, ±1 V
http://digital.ni.com/public.nsf/allkb/32C533AF9AFAF3B38625746E004A510F?OpenDocument
http://digital.ni.com/public.nsf/allkb/0C72E5621A14FDFB8625794D00193710
啟動 labview help >> 索引 >> 9636 >> 可以找到 9636 ( FPGA interface )
You can use an FPGA I/O Node, configured for reading and writing, with this device.
Use the FPGA I/O Node to access the following terminals for this device.
| Terminal | Description |
| Connector0/AIx | Analog input channel x, where x is the number of the channel. The NI sbRIO-9636 has AI channels 0 to 15. |
| Connector0/AOx | Analog output channel x, where x is the number of the channel. The NI sbRIO-9636 has AO channels 0 to 3. |
| Connectorx/DIOy | Digital input/output channel y on connector x, where y is the channel number and x is the connector number. The NI sbRIO-9636 has channels 0 to 27. Use the FPGA I/O Node or the Set Data Output or Set Data Enable method to access this channel. |
You can configure the arbitration settings for the DIO channels of this device in the Advanced Code Generation page of the FPGA I/O Properties dialog box. The default arbitration setting is Never Arbitrate.
Use the FPGA I/O Method Node to access the following I/O methods for this device.
| Method | Description |
| Set Output Data | Refer to the FPGA I/O Method Node topic for a description of this method. |
| Set Output Enable | Refer to the FPGA I/O Method Node topic for a description of this method. |
This device does not support any module methods.
Use the FPGA I/O Property Node to access the following properties for this device.
| Property | Description |
| Terminal Mode | Sets the terminal mode for a channel as RSE (referenced single-ended) or DIFF (differential). This property overwrites the value you configure in the FPGA I/O Properties dialog box. |
| Voltage Range | Sets the input range for a channel as ±10 V, ±5 V, ±2 V, or ±1 V. This property overwrites the value you configure in the FPGA I/O Properties dialog box. |
接下來請參考範例 find examples>>
並無選項可設定
並無選項可設定
| Voltage Range |
並無選項可設定
如附檔,請問是那裡沒設好,我都沒法設定 |
