NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
Error 200946
本來作用全無問題的程式
現在打開時DAQ卻出現這項錯誤訊息?
我相信我電腦或是DAQ無做其他更動卻發生了這樣問題
請問這是怎會出現這error
0 積分
1 條訊息(共 3 條)
5,868 檢視
補個說明
Task could not be started, because the driver could not write enough data to the device.  This was due to system and/or bus-bandwidth limitations.
Reduce the number of programs your computer is executing concurrently.  If possible, perform operations with heavy bus usage sequentially instead of in parallel.  If you can't eliminate the problem, contact National Instruments support at ni.com/support.
Measurements: Task could not be started, because the driver could not write enough data to the device.  This was due to system and/or bus-bandwidth limitations.
0 積分
2 條訊息(共 3 條)
5,867 檢視
您好:
建議您將 Start task 擺在迴圈外面,
或是將 I/O 重新設定和重新開機試試。
同樣的error code,可以參考此連接:
http://forums.ni.com/t5/LabVIEW/Error-200946-occurred-at-DAQmx-Start-Task-vi/m-p/320297
希望能解決您的問題
0 積分
3 條訊息(共 3 條)
5,856 檢視
