NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
How to connect external trigger PCIe-1433?
I am having an issue getting the external trigger to work using a cameralink camera(e2v UM4CL8007), a PCIe-1433 card and a signal generator(AD LINK PCI-8164 Motion Card).  The signal generator is connected to the SMB connector on the 1433 card and is providing  TTL voltages (0-5V).
0 積分
1 條訊息(共 2 條)
5,974 檢視
請參考1433 SMB Trigger的規格: http://www.ni.com/pdf/manuals/374001b.pdf
您可透過Example Finder尋找LL Occurrence Grab.vi,參考範例程式中的"IMAQ Occurrence Config2.vi"來設定Rising Edge或是Falling Edge進行trigger。
0 積分
2 條訊息(共 2 條)
5,965 檢視
