NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
How to using ROI Region to Image Threshold (by NI Vision)?
已解決!
前往解決方案
I use C# and NI Vision development 2010 sp1,
I want to set ROI Region to Image Threshold
ex:
But,Thresold function must use VisionImag to Computing, as below parameter1 & parameter2...
public static  void Threshold(
VisionImage source,
VisionImage destination,
Range range,
bool replaceValue,
double newValue
Now I just can Extract a new VisionImage to Threshold, and ImageToImage the new VisionImage to Origin VisionImage,
but it just can use a retangle to Extract Image,
How can I to use RotatedRectangle, Oval or Polygon ROI to achieve my function??
0 積分
1 條訊息(共 5 條)
6,704 檢視
Did you try to use Vision Assistant first before you try going deep into the C# code?
Vision Assistant helps you to prototype the application and it is easier to use.
0 積分
2 條訊息(共 5 條)
6,690 檢視
Excuse me, I already have to try Vision Assistant,
but the threshold function of Vision Assistant only set gray level or autothreshold choice,
I can't set roi region to threshold.
I look for the help document, as below...
   VisionImage source,
   Range range,
   bool replaceValue,
   double newValue
public static Collection<ThresholdData> AutoThreshold(
   VisionImage source,
   int numberOfClasses,
   ThresholdMethod method,
   VisionImage mask
AutoThreshold function seem to use mask to achieve ROI region to threshold,
but I want to use manual threshold function that must use threshold function,
why threshold function have not mask parameter???
0 積分
3 條訊息(共 5 條)
6,681 檢視
解決方案
由主題作者所接受 yflin
Hi yflin,
I think this is what you want to do in the Vision Assistant.
You can check my attched script and image.
0 積分
4 條訊息(共 5 條)
6,676 檢視
極度高興的表情
That's right.
It is my demand.
Thanks for your repply.
0 積分
5 條訊息(共 5 條)
6,664 檢視
