NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
LabVIEW Build DLL Return Value
已解決!
前往解決方案
Hi All
I know LabVIEW can build a DLL with return value with a function prototype like
void functionname (arguments);
We could set the return value at arguments.
However, could LabVIEW build a DLL with return value instead of "void" such us
int functionname (arguments);
If so, how?
Please don't be angry if this question has been asked before,   I'm lack of familarity
of LabVIEW communicating with other languages.
Thank you
Kirika
0 積分
1 條訊息(共 2 條)
4,137 檢視
解決方案
由主題作者所接受 Kirika
hi Kinka,
If you build a VI with numeric indicator, and connect it to the connector pane.
When you build the dll, you can select it to be the return value as shown in the attached image.
NITW AE Chuck
0 積分
2 條訊息(共 2 條)
4,103 檢視
