NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
Labview for Tic Tac Toe
 As shown below, I circled in red. What are the intentions of those components?
If possible, can you explain in detail the purpose of all the components
I am new to labview, and I want to understand the role of the whole
0 積分
1 條訊息(共 2 條)
2,514 檢視
Understanding LabVIEW is much more than knowing isolated items on the diagram. For example, you need to understand dataflow and all it's principles.
Start here to learn
I strongly advise against trying to learn LabVIEW from some questionable random code found somewhere on the internet, because you cannot judge the quality of the code and might just learn really bad habits. 😉
From a quick glance at the code, I immediately see huge room for improvements. Nobody should program like that!
Obviously this is NOT your own code, and it would only be polite to give a link where you found it. Maybe we can then see who the programmer is and if the code has been discussed already.
Note that this is only a passive board to be operated by the players. There is no AI. (In contrast, this old code cannot be beaten at the much more complicated 4x4 version).
0 積分
2 條訊息(共 2 條)
2,428 檢視
