NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
Labview8.2於Vista 64bit安裝
您好:本人下載Labview8.2試用版於Vista 64bit上安裝,但會出現register錯誤的情形發生而無法安裝,但使用Labview8.0版本卻可以在Vista 64bit上正常使用,請問這是什麼問題呢?
由 roy1 在 04-04-2007 03:20 AM 上編輯的訊息
0 積分
1 條訊息(共 6 條)
6,085 檢視
Hello roy1
NI 的說法是 LabVEW 8.2.0 不支援 Vista 64,8.2.1 才正式支援。有人是說其實安裝上去通常也沒問題就是。
你可以先確定你下載的是不是 8.2.1 還是 8.2,另外或許你可以將錯誤訊息 print screen 下來貼出來,這樣
大家比較容易幫你看是什麼問題。
0 積分
2 條訊息(共 6 條)
6,039 檢視
AE KB 4577J3BE: Installing LabVIEW in Microsoft Windows Vista x64 Edition
http://ae.natinst.com/operations/ae/public.nsf/web/searchinternal/e9b4ea0143514dcb8625725d0050680a?O...
0 積分
3 條訊息(共 6 條)
6,028 檢視
AE KB...
小老百姓看不到...
0 積分
4 條訊息(共 6 條)
5,908 檢視
LabVIEW 8.2.1已經release for support Vista,以下文章,Windows Vista 32位元與64位元版本差異?有提到32bit軟體的相容性問題
http://www.synnex.com.tw/asp/newsdetail.asp?topic=NW&classifyid=01928&seqno=19240&page=&listtype=2&c...=
0 積分
5 條訊息(共 6 條)
5,895 檢視
Title:
Problem:
My computer is running the 64-bit edition of Microsoft Windows Vista and I want to install a 32-bit version of LabVIEW 8.2.1 (or later). How do I install LabVIEW or any other National Instruments software that is not 64-bit in Microsoft Windows Vista x64?
Solution:
Microsoft has embedded backwards compatibility into Windows Vista x64 in order to support applications that have not been recompiled to use 64-bit pointers for 64-bit address spaces. WOW64, which stands for Windows On Windows 64 is an emulation layer that encapsulates applications that are designed for 32-bit applications. The application thinks it exists within the virtual memory of a 32-bit computer and sends and receives 32-bit commands, which are then translated by WOW64 before communicating with the system. No additional steps are necessary to take advantage of the WOW64 emulation layer. Install LabVIEW normally.
Drivers for Microsoft Windows x64 must be compiled for 64-bit. No emulation layer is provided for the system address space, which communicates with the kernel and system hardware. 64-bit drivers will be released for all National Instruments hardware once Microsoft Windows Vista x64 has been made available to consumers.
0 積分
6 條訊息(共 6 條)
5,879 檢視
