NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
NI-9066 方波計數
使用NI-cRIO-9066.9215.9402
有一連續 pulse訊號(由9215讀取),我要每隔80個pulse給一個trigger訊號(由9402輸出),在 FPGA 的環境下該怎麼寫?
0 積分
1 條訊息(共 2 條)
2,389 檢視
Hi
關於NI9215讀取訊號的相關資料與範例:
1.NI 9215 (FPGA Interface)
http://zone.ni.com/reference/en-XX/help/373197L-01/criodevicehelp/crio-9215/
2.NI 9215 Module Specific Example for cRIO or Other FPGA Target (Simple AI)
https://forums.ni.com/t5/Example-Programs/NI-9215-Module-Specific-Example-for-cRIO-or-Other-FPGA-Tar...
3.Problem with read value from analog input module on CompactRIO
https://forums.ni.com/t5/Real-Time-Measurement-and/Problem-with-read-value-from-analog-input-module-...
關於NI9402輸出pulse的相關資料與範例:
1. Coding cRIO 9402 DIO on FPGA
https://forums.ni.com/t5/LabVIEW/Coding-cRIO-9402-DIO-on-FPGA/td-p/1479924
2.Generate a pulse train, NI 9402 modules in cDAQ-9174 chassis
https://forums.ni.com/t5/Counter-Timer/Generate-a-pulse-train-NI-9402-modules-in-cDAQ-9174-chassis/t...
0 積分
2 條訊息(共 2 條)
2,221 檢視
