NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
NI LabVIEW 2013 FPGA Module Xilinx Tools 10.1 與 14. 4的 差異
請問NI LabVIEW 2013 FPGA Module Xilinx Tools 10.1 與 14.4的差異在哪?
是只有差別在10.1用在Virtex-II FPGA.,而14.4則用在非Virtex-II FPGA上嗎?
KNR在labview 2011的安裝中有用到FPGA Xilinx 10與FPGA Xilinx 12,這兩者的差異在哪?
0 積分
1 條訊息(共 2 條)
5,799 檢視
http://digital.ni.com/public.nsf/allkb/A4B20D58C051DFB386257A56007BB0B2
http://digital.ni.com/public.nsf/allkb/ED6FC9CF7B983CFD86256DCE0072E313?OpenDocument
The version of the compile tools you need depends on your version of LabVIEW, with one exception.  If you are compiling to a device that uses a Virtex II chip, then LabVIEW versions 2010-2012 require the Xilinx Compile Tools 10.1 rather than the version listed in the table below. To install the Xilinx Compile Tools, refer to the Related Links section or to the Platform DVDs included with the LabVIEW FPGA Module.
0 積分
2 條訊息(共 2 條)
5,792 檢視
