NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
Notebook 內建的 Modem 要如何控制?
請問各位前輩 Labview要如何控制,Notebook內建的Modem或是,PCI介面的Modem,我試著先察看裝置管理員,發現他有被分配COM Port,然後我就用VISA跟他通訊卻一直Error 訊息如下
VISA:  (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
0 積分
1 條訊息(共 3 條)
5,637 檢視
You can configure and communicate with your modem sending commands to it through its assigned COM port using serial or visa VIs and functions. Most modems use the Hayes AT Command Set. These are short commands strings each prefaced by the letters AT (for "attention"). This Knowledge Base describes some basic syntax for AT commands and gives examples of commands that can be used to dial and hang up. To get more information about the commands that your modem supports, please refer to your modem's user manual.
Some modems respond to the "AT$" command by returning the modem's supported command set as a form of online help. After installing the modem in your computer, you can check the COM port that it was assign to by going to Start» Settings» Control Panel» Modem. Each modem has an initialization string which consist of a series of commands that set the communication parameters of the modem such as the dialing mode, busy signal detection, and many others. Again, please refer to your modem's user manual for the appropriate initialization string.
A command string should start with "AT", except for the commands "A/" (repeat command) and "+++" (escape). The modem will not respond to any commands not preceded by an AT. The commands can be typed in either lower case or upper case, but not mixed. Several commands can be typed in one line. In general, each line can contain up to 40 characters, including spaces and carriage returns. Commands and command strings must be terminated with a carriage return, except +++ and A/.The following table contains some of the frequently used commands:
Command Description
AT ATtention - This prefix begins all commands but "A/" and "+++"
+++ Escape - Allows you to return to command mode to reset the configuration after you have connected to another modem or to hang up
A/ Repeat last command
D Dial command - Format of the command: ATD [string], where [string] is the telephone number. It can contain up to 45 characters
P Pulse dialing - This command modifies the D command. Format of the command: ATDP[string]
T Tone dialing - This command modifies the D command. Format of the command: ATDT[string]
E<0 or 1> Echo mode (0=OFF, 1=ON) - When echo is turned on, the modem will return all commands back to computer, instead of replying with an OK or a zero when the command is executed
H<0 or 1> 0-Hang up phone, 1-Go off hook
I Inquiry - returns information about the modem
M Monitor speaker (0=speaker off, 1=speaker on)
Z Modem reset
$ Returns
For example to dial 800-433-3488 using tones, send
+++ATDT8004333488
To find more information about AT commands, see the link below titled "The Hayes Command Set" or search on the Internet for "Hayes AT Commands". You can also take a look at the Communication Toolkit developed by one of our Alliance Members, Microsys, in the link below.
0 積分
2 條訊息(共 3 條)
5,613 檢視
感謝 derek wu 在您的解答後,我的問題已解決了........感謝
0 積分
3 條訊息(共 3 條)
5,602 檢視
