I was able to plot the file to labview however I couldn't plot the points to XY graph in labview~
(I used the example from http://zone.ni.com/devzone/cda/epd/p/id/3409 )
However, after I wired up all the elements in the block window it gave me a straight line....it gotta be something wrong with the array..but Im still new to labview that I can't figure out how to fix it~
Thanks for the help~
在 06-23-2009 01:46 AM
請使用 index array
XY Graph 接受 1-d array
