NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
Uninstall Cannot Proceed (CVI)
2017-11-17_002330.pngHi NI & ALL
env. CVI 2010,
I packet my files and installed it, but I can not run uninst.exe.
How to fix this problem?
Help me, please....
0 積分
1 條訊息(共 4 條)
3,086 檢視
What happens if you follow the instructions on the popup dialog?
0 積分
2 條訊息(共 4 條)
3,064 檢視
In Windows Control Panel, Remove Program is well.
But I want to use uninst.exe to remove this application.
(Not just a pop-up message) What should I do?
Thanks for the prompt reply.
0 積分
3 條訊息(共 4 條)
3,040 檢視
What if you run it as admin? (right-click...run as administrator)
0 積分
4 條訊息(共 4 條)
3,032 檢視
