NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
add value to waveform chart x-axis
I get the temperature, power and time from the equipment. I use the time as x-axis, and temperature and power as y-axis. How to add more number of value to x-axis?
Above waveform chart has six element in x-axis. I want to more number of element in x-axis. The case similar to zoom out. Please advice. Thank you.
0 積分
1 條訊息(共 2 條)
5,608 檢視
Hi st168,
If you want to add more scales within the same x-axis range for display, you could simply:
1. Right-click the Waveform Graph
2. Choose "X Scale" --> "Style" and select the one which locates at first column and third row.
Or if what you want is to expand the x-axis observation range, you could:
2. Choose "X Scale" --> "Properties" and select "Scales" tab
3. Unchecked "Autoscale" and then enter the minimum and maximum number to set the observation scope.
Best Regards,
cpan
0 積分
2 條訊息(共 2 條)
5,595 檢視
