NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
chart 連接 fft
我已經有一個自己POLT 出來的chart 但吾可以好像Simulate Signal 駁入FFT 裏,如何可以把自己的chart 駁入FFT 裏??
下載全部
0 積分
1 條訊息(共 8 條)
7,140 檢視
可以麻煩您以正體中文再說明一次問題嗎?另外,方便的話請提供您程式的block diagram以利釐清問題成因。謝謝!
0 積分
2 條訊息(共 8 條)
7,123 檢視
How to use the XY GRAPH to connect FFT??
THX ^^
0 積分
3 條訊息(共 8 條)
7,115 檢視
Sorry! Re-upload the vi
0 積分
4 條訊息(共 8 條)
7,103 檢視
X Y Graph 需要很多的 ( Xn, Yn ), n = 0,1,2,3,4....etc
所以如果您的輸入不是上述的座標,當然無法顯示
0 積分
5 條訊息(共 8 條)
7,093 檢視
Thank you ^^
I can connect the XY graph , but I can't connect the FFT. How to do it ?? THX
0 積分
6 條訊息(共 8 條)
7,086 檢視
Hi EdwinAAA,
The reason why you got broken wires is that the Spectral Measurement express VI only takes "waveform" datatype as input. I guess you confused "XY Graph" with "Waveform Graph," please refer to the following tutorials:
Waveform Graph: http://www.labviewpro.net/teach_content.php?fid=6&post=307&fpt=5
XY Grpah: http://www.labviewpro.net/teach_content.php?fid=6&post=308&fpt=5
To solve your problem, the function "Build Waveform" is helpful. Below is how I utilized it:
The Result: Have a look at the upright "Waveform Graph"
Hope the above information is useful. Please come back and keep us posted.
Phil
0 積分
7 條訊息(共 8 條)
7,081 檢視
Hi, SmilingPhil,
Big Big thank you for your help. The information is very useful.
However, the waveform graph of the vector is not the integer. Can you help me. THX THX ~~~~
下載全部
0 積分
8 條訊息(共 8 條)
7,072 檢視
