NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
gpib
各位先進:
        您們好,想跟大家詢問一個純粹扮演Listener角色的程式要如何撰寫
    之前購買了一張 PCI-GPIB/TNT5004 的卡,裝上PC後串接到[Control PC-Tester-Handler]迴路中
    使用GPIB Analyzer可以在測試過程中純粹監聽到訊息,而如果使用所附的sample code時
    未什麼在初始化Device就會發生Error,Error Message 與Source code如下
    想請教大家一個扮演純粹監聽角色的程式,有哪些設定值要預先設定與注意 Thanks!
Error Message:
     Error opening device.
     Ibsta:0x8100
     REE:1<ECIC>
下載全部
0 積分
1 條訊息(共 7 條)
7,222 檢視
Dear Ting1224
透過GPIB Analyzer可以監聽到Tester與Handler的訊息,GPIB Analyzer設定資料畫面如附檔所附。
而透過下列的Code 為何無法監聽到如同GPIB Analyzer的訊息呢?謝謝您。
Imports NationalInstruments.NI4882  'must be included to reference the LangInt assembly
Imports VB = Microsoft.VisualBasic  'included for string manipulation
Module Module1
    Const BDINDEX = 1              ' Board Index
    Dim li As LangInt                   'declare li of type LangInt that has all GPIB functions
    Dim c As GpibConstants              'declare c of type GpibConstants that has all GPIB constants
    Sub Main()
        li = New LangInt                    'declare an instance of li
        c = New GpibConstants               'declare an instance of c
        Dim noncontroller As Integer
        Dim buffer As String
        Dim panelHandle As Integer
        Dim listen As Short
        noncontroller = li.ibfind("gpib3")
        'Release system control
        li.ibrsc(noncontroller, 0)
        li.ibpad(noncontroller, 13)
        li.ibsad(noncontroller, 126)
        li.ibtmo(noncontroller, c.T10s)
        li.ibeot(noncontroller, 1)
        li.ibeos(noncontroller, 0)
        li.ibclr(noncontroller)
        li.ibln(noncontroller, 13, 126, listen)
        li.ibwait(noncontroller, 0)
        '// Wait until non-controller is listener and ATN line is dropped.
        While True
            If ((li.ibsta And c.LACS) And (Not (li.ibsta And c.ATN))) Then
                li.ibrd(noncontroller, buffer, 100)   ' Read data bytes
            End If
            'If addressed to talk, send the response "I am a talker"
            If ((li.ibsta And c.TACS) And (Not (li.ibsta And c.ATN))) Then
                '// Send data across the bus.
                li.ibwrt(noncontroller, "I am a talker", "I am a talker".Length)
            End If
        End While
    End Sub
Best Regards
Robins
0 積分
3 條訊息(共 7 條)
7,191 檢視
不好意思之前忘了提醒你, 這次才看到。
要使用GPIB Analyzer,你必須要有GPIB+的硬體才可以。
你可以參考以下連結
http://digital.ni.com/public.nsf/allkb/848F027883BD6429862571B8001DFEDC
To use the GPIB Analyzer you must have a GPIB+ interface, regular GPIB hardware does not have the analyzer hardware that is necessary.
GPIB+的硬體有以下這幾張
AT-GPIB/TNT+, PCI-GPIB+, and PCMCIA-GPIB+
0 積分
4 條訊息(共 7 條)
7,189 檢視
Dear Ting1224:
謝謝你的提醒,目前已可以使用GPIB Analyzer 當成Listeners 在另一台
電腦,聽取到 Tester與Handle 間傳遞的訊息,詢息畫面在上一個所請教
的問題裡有附上圖片。另外想跟您請教,上一個所請教的問題所附的
Source Code哪那一個所下的指令所做的設定應該需要修改,
才能讓這個程式在另外一台電腦上扮演Listeners的角色,
接收到Tester與Handle 的訊息間傳遞的訊息,謝謝您。
Best Regards
Robins
0 積分
5 條訊息(共 7 條)
7,175 檢視
li.ibrsc(noncontroller, 0) 就是把SC(System Controller)設成False (0)
noncontroller是原程式設計者定義GPIB3這張Board的Reference,
所以把noncontroller這張卡設為false代表這張卡為Listeners。
0 積分
6 條訊息(共 7 條)
7,166 檢視
您好,
我用C# 開發GPIB+的程式,
請問我要如何知道GPIB+ BUFFER上的資料是PC端還是儀器端傳來的??
0 積分
7 條訊息(共 7 條)
3,740 檢視
