NI製品ディスカッション
キャンセル
次の結果を表示
次の代わりに検索
もしかして:
How to reduce the noise signal
Dear LabVIEW Engineer
I am using  NI developer suite 2010 with machine vision and fuzzy controller toolkit.
I get noise data as the output from machine vision.
What kind of signal processing function to stabilize the noise ?
Another request, could you give link the example of the sequence structure function?
Thank you
Best regards
Sugeng
0 件の賞賛
メッセージ1/2
3,419件の閲覧回数
Tokyo Metropolitan University
Dear Sugeng Supriadi,
This is Hiroaki, an application engineer from NIJapan.
If you have Signal Processing Toolkit, then there are digital filter functions in the pallette of "信号処理">Digital Filter Design as shown in the attached screen shot.
Instead of introducing the link, I created a good sample VI using the sequence structure.
Please take a look at the attached VI. Sequence structure is used whenever you want to define the order of
being processed. Each frame is processed in order.
Hiroaki
Hiroaki Ito | National Instruments | Application Engineer
0 件の賞賛
メッセージ2/2
3,392件の閲覧回数
