NI製品ディスカッション
キャンセル
次の結果を表示
次の代わりに検索
もしかして:
analog out control using VEE
hi there,
i'm trying to control analog output voltage of NI-USB-6008 with agilent VEE9.2. does any one know how to do that? i have tried such sequence as attached, however it doesn't work.
thank you.
0 件の賞賛
メッセージ1/6
3,820件の閲覧回数
Dear Skaaji,
Good morning.
Thanks for using NI discussion forum.
Please make sure that the device name is correct. You can check it from the Measurement and Automation software of National instrument.
I am really sorry we can't help you much about the programming in Agilent VEE.
Could you please consult with Agilent how does its software work with DAQ devices and please check its compatibility with National Instrument devices.
regards,
Muhammad
0 件の賞賛
メッセージ2/6
3,793件の閲覧回数
Dear Muhammad,
thank you very much for respond.
yes, i think the device name is correct (Dev2/ao0), the same name as the MAX says.
the VEE 9.2 identifies NI USB-6008 and creates what VEE calls "driver object", so compatibility seems no problem.
well, thank you anyway. i will try different approach.
skaaji
0 件の賞賛
メッセージ3/6
3,788件の閲覧回数
Dear Skaaji,
Thanks for the reply.
As device is recognized on MAX, most probably its device setting and programming issue in Agilent VEE causing error this time.
Is it first time you are controlling USB-6008 through Agilent VEE?
You can test USB-6008 using MAX following the instructions mentioned in the link below.
http://zone.ni.com/devzone/cda/tut/p/id/4638
Please let me know if you have further questions in this regard.
regards,
Muhammad
AE, NIJ
0 件の賞賛
メッセージ4/6
3,778件の閲覧回数
Dear Muhammad,
i could finally figure out how to do that.
"http://forums.ni.com/t5/Multifunction-DAQ/Using-Agilent-VEE-7-5-with-DAQPad-6015/td-p/369017"
was a good help to see how should the series of commands flow.
thanks anyway for your kind and quick response.
regards,
skaaji
0 件の賞賛
メッセージ5/6
3,745件の閲覧回数
Dear Skaaji,
Thanks for the link above.
I am glad to know that you could find a workaround to your problem.
While going through it, i came across this link  addressing the device access issue with agilent VEE .
Thank you very much for using NI Discussion forum.
Please feel free to contact us if you have further questions.
regards,
Muhammad
AE, NIJ
0 件の賞賛
メッセージ6/6
3,734件の閲覧回数
