NI Circuit Design Community Discussions
Import a DXF file
I know that Ultiboard is able to import DXF files.
But my customer needs to import a contour for his PCB. So the shape should not be edgy.
He is using Pro Engineer and maybe could also use a different file format, but he prefers DXF.
Thanks a lot for you quick replies in advacne 😉
Greetings from Austria
Bernhard
(9,618 Views)
Hi Bernhard,
To import a board contour into Ultiboard, the DXF import could be used as well. Simply map the imported DXF shape to the board outline layer.
Thank you,
Mahmoud
(7,564 Views)
Hi Mahmoud,
thanks a lot for your quick reply. The problem is that I do not know who to do it and also the customer does not.
Could you please send me a few instructions or screenshots how to do it?
This would be really great.
Bernhard
(7,564 Views)
Hi Bernhard,
Here is a tutorial on how to accomplish this task:
http://www.ni.com/white-paper/13722/en
Let me know if you need anything else,
Mahmoud
(7,564 Views)
Hi Mahmoud,
thank you so much!
Sure I will 😉
Bernhard
(7,564 Views)
