NI Circuit Design Community Documents
LabVIEW Instrument for Multisim: Digital Waveform Generator
This example program which include NI Multisim and NI LabVIEW is one in a series which showcases the power of using advanced LabVIEW instruments within the simulation environment. All instruments are based upon a virtual instrument template found in the Multisim sample folder. Any LabVIEW user can easily take this template and define an instrument which can input complex signals, or visualize simulation data within Multisim.
The NI6551 waveform generator allows you to emulate the look and behavior of the same instruments that will act as a prototype stimulus. In this instrument you can input a pre-defined waveform, or generate one during the validation process.
More info on the tool and how to use it take a look at: https://forums.ni.com/t5/Example-Code/Archived-Digital-Waveform-Generator-Using-the-NI6551-Instrumen...
