NI Circuit Design Community Documents
NI Hardware Connectors: Ultiboard Database Upgrade
You can use the Symbols and Landpatterns in this free database upgrade, in order to build prototypes in Multisim and Ultiboard that interface to NI hardware (such as CompactRIO, Single-Board RIO and M-Series DAQ).
Read the following online article to learn more about how to install and use these connectors: https://www.ni.com/en/support/documentation/supplemental/09/ni-connector-reference-library-for-multi...
The attached zip folder contains datasheets for the connectors, database upgrade as well as an example file
