NI ELVIS
Elvis - 1 software and driver
Hi, I have a (very old) Elvis I board and would like to give it to a student. I do not have the driver and software installation CD anymore. I know that it is not anymore supported by NI, but I really want to make it work. Is there someone here who still has the drivers and the software, or is there a possibility to download it somewhere?
thank you
Bernd
(2,768 Views)
Hello!
You can download the ELVIS driver from NI's FTP server here: https://download.ni.com/#support/daq/pc/ni-elvis/
Please note that you will need an E Series DAQ device and a corresponding 68-pin cable. You will also need DAQ 7.3 (or later), and LabView 7.0 (or later). If you need older DAQ drivers, they are available on the NI FTP server- but it should work with the newer DAQmx drivers. For best results, you will probably need to use Windows XP.
The user manual for the NI ELVIS can be found on our website, under the "Manuals & PDFs" tab, here: https://www.apexwaves.com/modular-systems/national-instruments/ni-elvis/NI%20ELVIS
Additional links you might find useful:
DAQmx Download
Traditional DAQ Download
LabVIEW Download
Hope this helps!
(2,716 Views)
Thank you very much !
(2,709 Views)
