NI ELVIS
NI ELVIS III - Safe Mode - Improper Installation
My ELVIS III will only boot into safe mode.  The status LED flashes twice every few seconds.  I can login to the device via NI MAX and it shows "Improper Installation".
I have attempted to re-install the software via the software wizard.  The device is currently running NI ELVIS v18.5.  This version is unavailable within the wizard to re-install.  I then attempted to install v19.0 where I get the below error:
"Error while reading a file from the local disk.  The file may be corrupt or not present."
I have tried to first uninstall the software via the software wizard but received the same error above.
I have not touched or attempted to upgrade the firmware.
I can connect to the device via Wi-Fi or Ethernet.  I am unable to connect via USB.
I would love any suggestions that anyone could provide.
(3,131 Views)
Issue was fixed with the below article.
Error While Reading From the Local Disk When Formatting Real-Time Target
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7iQSAS&l=en-US
(3,071 Views)
