NI ELVIS
troubleshoot NI ELVIS DMM and VPS
I am a new NI ELVIS user and was beginning with the tutorial given in http://www.ni.com/tutorial/13559/en/  link
Need some help regarding  Exercise 1.2. Building a Voltage Divider Circuit on the NI ELVIS II Protoboard.
Made the connections to variable power supplies terminals SUPPLY+ and GROUND as input
DMM terminals DUT+ and DUT- as output. Opening the NI ELVIS Instrument Launcer and running VPS and DMM I should have obtained the voltage across the resistor. But my voltmeter panel shows a constant and a minimum voltage about -.405mV.
How do I troubleshot the error or did I skip any step?
Message 1 of 1
(4,219 Views)
