NI FlexRIO Network
Compilation error for a complex multiplication.
I am trying to compile a subVI having HDL interface node.
I've wrapped up a VHDL code, generated by xilinx logiCore, with a HDL interface in LV.
A function in VHDL has a complex multiplication, and a data sheet said that it would be synthesized with
DSP48e in Virtex-5 target. When I compile it, i got an error as follows:
>Status: Compilation failed due to a Compile Server error.
> Regenerating IP...
> ERROR:sim - Complex Multiplication : false is invalid.Finished Regenerating.
> ERROR:sim:57 - Error found during generation
Data sheet said that it  'Complex Multiplication' is always selected in virtex-5 target.
I guess that  ' Complex Multiplication' became 'false' during the compilation by some reason.
Do you have any idea to compile this successfully?
(5,626 Views)
Sorry,
In xilinx logiCore, I choose a wrong FPGA target  when I generate VHDL code.
Let me try to compile it with a new code.
*Updated*
Please ignore this message. It's compiled well with a new code.
(3,697 Views)
