NI FlexRIO Network
Issue with I2C EEPROM Simulation on FlexRIO
I'm attempting to simulate some I2C code which will write data into the adapter module EEPROM.  I have found that I can build the I2C code into a bitfile, however I can't get the simulation build to complete.  I get the following error (-61499):
I noticed that if I disable some of the blocks:
and then remove the i2crddata line and replace it with a constant (so: 'i2crddata' I/O pin would be replaced with a constant number '0' (in FXP) for example)
It will build successfully and I have no clue why....
I've zipped and attached the LV project for reference which includes the full code and CLIP.
Anybody know why this is happening?
(5,650 Views)
Hello!
For this issue, I would suggest creating a service request at ni.com/support with one of our Applications Engineers. They will be able to help debug/troubleshoot this situation as well as be able to access the applicable internal resources to investigate this issue.
Ben Sisney
FlexRIO V&V Engineer
(4,709 Views)
