NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
分列读取文本文件
已解决!
转到解答
请教:我要分列读取文本文件,例如
column1       column2
 1                 8
 2                 5
 4                 2
前面板上分别显示1 2 4
                         85 2
要怎么做?
0 项奖励
1 条消息(共 7 条)
6,521 次查看
从哪读?txt吗?
有个Read From Spreadsheet File.vi可以读txt
Thomas | Xi'an China
LabVIEW 7.1 | LabVIEW 2018
DAQmx | CompactRIO | myRIO
微信公众号: 钟博士LabVIEW工作室
2 条消息(共 7 条)
6,514 次查看
解答
已被主题作者 meiyan 接受
You may use Spreadsheet String To Array function to convert the tab-delimited text data into array, and with Index Array, Concatenate Strings and Format Into StringTranspose 2D Array and For-Loop etc to transform the data to the desired arrangement.
PS: it is assuming that the text data file is of tab-delimited
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
3 条消息(共 7 条)
6,512 次查看
With Thomas solution, all you need is Transpose 2D Array the 2D array output.
Just wire the transpose input of Read From Spreadsheet File to TRUE 😉
Message Edited by ian fung on 01-19-2010 03:35 PM
Ian F
依恩与LabVIEW
4 条消息(共 7 条)
6,508 次查看
哦,对,转置数组。
0 项奖励
5 条消息(共 7 条)
6,503 次查看
i noticed that you use a "transpose to 2D array"to get a transposed array, but if the data is more than 2 columns,then how?
0 项奖励
6 条消息(共 7 条)
6,450 次查看
A Transpose 2D Array will transpose any 2D array with N-rows, N-columns.
More than 2 columns? It is, still, a 2D array, isn't it?
Ian F
依恩与LabVIEW
0 项奖励
7 条消息(共 7 条)
6,445 次查看
