NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
刚学习Labview, 有2个问题请教大家
刚刚学习Labview, 有2个问题请大家帮忙。我有一个用Labview做的exe文件,但是无法看到到它的block diagram. 请问如何能看到该文件的block diagram? 另外一个问题,当完成一个VI文件后,如何将它转换成exe文件?多谢
0 项奖励
1 条消息(共 6 条)
4,946 次查看
You can't see the block diagram after you build your vi to exe file, even NI's member can't do this.
And it's easy to use application builder to create .exe's and .dll's.
Lady And Basketball Vividly In my Exciting World !!!
Daniel.Tang E-mail: tangye@friendess.com
0 项奖励
2 条消息(共 6 条)
4,938 次查看
在前面板窗口双击你设置的控件就可以跳出相应的程序框图窗口,你可以试试看。
0 项奖励
3 条消息(共 6 条)
4,919 次查看
觀於封裝成exe的方法,請參考:http://www.labview.com.tw/forum/forum_posts.asp?TID=218
0 项奖励
4 条消息(共 6 条)
4,888 次查看
when build vi to exe, you can't see the block diagram. on how to build exe, the following link may help you
anyway,i would like to remind you, the file path will be changed after you build into exe, if you call other dynamic files or subvi.
so i suggest you to place all support into the same file directory.
regards
0 项奖励
5 条消息(共 6 条)
4,880 次查看
就像你用vc生成exe后,也是看不到源代码的
0 项奖励
6 条消息(共 6 条)
4,856 次查看
