Do you have the Trim Whitespace.vi under String functions palette?
I see... you should have mentioned that... some CVI experts might be able to give you the answer then... hope you will solve it soon 🙂
void RemoveSurroundingWhiteSpace (char string[]);
ian fung 写:Hi,
Message Edited by ian fung on 01-25-2010 11:08 AM
Hi, Sir
thanks for you helps, i have tested this command, it is really i want. en. looks you are also CVI expert 🙂
并不是因为我知道, 而是因为我努力查找 😉
PS: 虽然开始时有接触过CVI, 但因不太喜欢Text-based 编程, 所以自一九九九年都以LabVIEW为主...
