NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
图象处理方面内容(模式匹配)
我想使用模式匹配来进行图象检测方面的程序编写. 我通过学习得到一个模板信息并存入当前路径,在测试VI中读取模板信息信息与照相机获取的图象进行模式匹配.可是出现报错"错误的模板描述".
0 项奖励
1 条消息(共 4 条)
5,189 次查看
I think you have made a mistaken what is image type,
two recommended solutions:
1.) go to example finder to find more IMAQ example to study
2.) attach corresponding vi or attachments here for help.
________________________________________________________
Try to make everything Automatic
2 条消息(共 4 条)
5,167 次查看
Is the path to the template correct?
You'd better take a look at this example shipped with NI Vision: Pattern Matching Example.vi.
0 项奖励
3 条消息(共 4 条)
5,141 次查看
Thank you for your information.  I solve  it .  Because  I save the imaq mannually, not using the  subVI.
0 项奖励
4 条消息(共 4 条)
4,705 次查看
