NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
在MAX中是否能够看到连接在cRio 9022上连接的usb raw设备?
已解决!
转到解答
cRio9022已正确连接至电脑,usb raw设备用visa配置驱动后连在电脑的usb接口上也可以在MAX中正确识别。如果连接在cRio上面在MAX中看不到的话,如何确定设备已被9022识别并可用visa进行usb通信?
0 项奖励
1 条消息(共 5 条)
3,446 次查看
解答
已被主题作者 zhxzhlx 接受
As a RT system, you can not read the module on the cRIO system.
But you can create the "terminal and device..." in project manager in LabVIEW, and if you can call the related interface, you have linked the device correctly.
0 项奖励
2 条消息(共 5 条)
3,438 次查看
Thanks for your help! I will have a try!
 By the way,you have said "As a RT system, you can not read the module on the cRIO system." Does this means that i couldn't find the usb raw device in MAX on my computer either?
0 项奖励
3 条消息(共 5 条)
3,433 次查看
"As a outside RT system relative to your PC"
I am sorry to get a mistake in my describe.
0 项奖励
4 条消息(共 5 条)
3,430 次查看
OK! I see.Thanks!
0 项奖励
5 条消息(共 5 条)
3,427 次查看
