NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
在labview中能直接调用matlab的simulink文件吗?
labview可以直接调用matlab的文本文件,但能直接调用simulink文件吗?能的话如何调用,谢谢!
0 项奖励
1 条消息(共 3 条)
5,439 次查看
Are there anypeople know how to solve this problem?
 I will really appreciate your help!
0 项奖励
2 条消息(共 3 条)
5,427 次查看
The Simulation Interface Toolkit (SIT) provides a seamless integration between The MathWorks Simulink software and LabVIEW. The Simulation Interface Toolkit automatically generates LabVIEW code to interface with a Simulink model resulting in a flexible and easy-to-use user interface. You first must configure the Simulink model to communicate with LabVIEW. Then you can create a LabVIEW host VI that automatically calls, runs, and interacts with the Simulink model.
你可以看看这个链接http://zone.ni.com/devzone/conceptd.nsf/webmain/955A9D79583A0AB686256DB8006672B8
0 项奖励
3 条消息(共 3 条)
5,424 次查看
