NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
怎样实现实时采集数据的保存
数据通过串口采集出来,在屏幕上可以单个数据显示,同时也可以用图形表示出来了,现在我是想将这组数据保存下来。
0 项奖励
1 条消息(共 19 条)
8,426 次查看
你存到文件里头就行了
用中层的save vi
0 项奖励
2 条消息(共 19 条)
8,404 次查看
You can save your data to database, example to SQL server, Access, or to Excel. save a data as soon as getting.  that is very simple and available.
________________________________________________________
Try to make everything Automatic
0 项奖励
3 条消息(共 19 条)
8,404 次查看
请给个例子好吗?
0 项奖励
4 条消息(共 19 条)
8,393 次查看
You can type "file" in NI example finder (from Help menu), double click "file" ,then many many samples about save and read are showing to you. get what you want.
0 项奖励
5 条消息(共 19 条)
8,381 次查看
你用的版本是试用版?还是正式版?
0 项奖励
6 条消息(共 19 条)
8,378 次查看
Yes. On my personal PC is Evaluation one. on my Lab is full version.
0 项奖励
7 条消息(共 19 条)
8,377 次查看
完全版
0 项奖励
8 条消息(共 19 条)
8,373 次查看
Yukee
what is your lab?
Just in NI?
0 项奖励
9 条消息(共 19 条)
8,370 次查看
yulzhu,
           Sorry to give misleading word, Lab---my meaning is laboratory, and my personal pc means my office PC,  cause labVIEW's license, my office PC installed Evaluation one only, my job is building test station for our corporation's products in Shen Zhen. and you ? From forums that I think you are a good skill in labVIEW man, hope you can help the missing men who are in labVIEW or NI products.or the other...
we are using NI products many many, it is easy and so available for our testings.
0 项奖励
10 条消息(共 19 条)
8,368 次查看
