NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
怎样才能旋转图片90度?
0 项奖励
1 条消息(共 16 条)
8,602 次查看
Yes, it can be. there are not properties node to call achieved. you must be "rotary" image data to achieve.
if you don't know also. I can enclose a simple sample to you.
________________________________________________________
Try to make everything Automatic
0 项奖励
2 条消息(共 16 条)
8,586 次查看
Yes,yes!!!Thank you!!!
I tried using "Transpose 2D Array" to rotate the pic,but the characters are reversed.
I really have no idea how this could been done.
Thank you so much for helping me dealing with this.
0 项奖励
3 条消息(共 16 条)
8,583 次查看
It is easy, if only you know image data's principle ! *.*
See attachment !
4 条消息(共 16 条)
8,579 次查看
Attached is how the picture's angle you need .
0 项奖励
5 条消息(共 16 条)
8,576 次查看
Thank you very much!!
But there is still a problem unsolved.
Take a look at the bottom of this picture.The string "bbs.S460.net" has been reversed.Can I just rotate it without any reversal?
0 项奖励
6 条消息(共 16 条)
8,574 次查看
That's it.
Thank you so much.
You saved my life.:manvery-happy:
Thanks again.....
0 项奖励
7 条消息(共 16 条)
8,570 次查看
the string what you mentioned that is from picture, it is belong to original image data's element. not me appended !
would you add a string which needn't been rotary?
0 项奖励
8 条消息(共 16 条)
8,570 次查看
No,NO,it's not necessary.
As I remembered there is a function called "draw text in the rect" by which the string can be rotated, is that right?
I've never used that.
0 项奖励
9 条消息(共 16 条)
8,565 次查看
Yes "draw text in the rect" can rotate the text, but it cann't achieve image, only text.
from this case we would know more about image. image data. image's data principle .^.^
0 项奖励
10 条消息(共 16 条)
8,561 次查看
