NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
怎样用低版本的lv运行高版本lv文件
如题,比如用6.1打开7.1版本的程序
0 项奖励
1 条消息(共 4 条)
4,077 次查看
I cannot be done. Old version LabVIEW cannot open VI from higher version
John L.
0 项奖励
2 条消息(共 4 条)
4,062 次查看
It cannot be done. Old version LabVIEW cannot open VI from higher version
John L.
0 项奖励
3 条消息(共 4 条)
4,061 次查看
And this is interesting for me, that I want to know why NI doesn't support this kind of handles ?
and we know before labVIEW opens a vi file. labVIEW will detect the target vi's version about. and do a comparing, if the vi file's revision is higher than the labVIEW system.
labVIEW will prompt a dialog box to tell user " labVIEW revisioin XX cann't open ......"
As this condition, why labVIEW cann't detect the block diagram (software component) automatically. and find whether the vi file which is higher one's component contained by the lower labVIEW system ? certainly, we can accept, lower revision labVIEW cann't open the higher one which is at the higher labVIEW's vi, because lower labVIEW hasn't it. or open it. as the lower labVIEW hasn't latest vis, and show empty. it is similar with labVIEW opens a vi which contains many subVIs that cann't be found.
sometimes, though the vi file was programed by the highter labVIEW system. but its vis are contained by the lower labVIEW's system too. this chance that I met many years, there are about 70~80 percent.
if NI can solve this trap, I think that will help user or a new user more available. and I think this technology is not hard for NI.
________________________________________________________
Try to make everything Automatic
0 项奖励
4 条消息(共 4 条)
4,056 次查看
