NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
急问:PCI6221的第8pin+5V电源变成0.3V了,为什么?
我记得PCI6221第8pin外最多可输出1A的电流,所以我就利用它作为外部一些上拉电阻和芯片的+5V电源(其输出的总电流小于1A)。可是然后我再测量8角的电压,发现只有0.3V了。怎么办??是不是我把内部电路烧了??请求各位大侠帮忙解答一下,我实在是不知道为什么。随便问一下,PCI6221第8pin最大输出电流负载是1A吗?如果不是的话,那是多少呢?
先谢了!!!!
0 项奖励
1 条消息(共 7 条)
6,228 次查看
建议你和NI技术支持联系,去检测板卡。8PIN输出不是5V是有问题的。
帖子被cool_bigben在09-20-2005 06:46 AM时编辑过了
0 项奖励
2 条消息(共 7 条)
6,225 次查看
+5 V Power Source
The +5 V terminals on the I/O connector supply +5 V referenced to D GND. Use these terminals to power external circuitry. A self-resetting fuse protects the supply from overcurrent conditions. The fuse resets automatically within a few seconds after the overcurrent condition is removed.
Power rating (most devices)–+4.65 to +5.25 VDC at 1 A
Refer to the specifications document for your device to obtain the device power rating.
Note  The NI 6221 (37-pin) device does not have a +5 V terminal.
Caution  You should never connect the +5 V power terminals to analog or digital ground or to any other voltage source on the M Series device or any other device. Doing so can damage the device and the computer. NI is not liable for damage resulting from such a connection.
请提供更详细一点信息,关于您对这5v引脚的操作,以便更好的分析。
0 项奖励
3 条消息(共 7 条)
6,215 次查看
it seems that the 8 pin +5v has been destroyed. anyway, you should consider the value of up-pull resistor and current, and use multimeter to measure it before connect it.
suggest you to contact NI with above phone number!
regards
0 项奖励
4 条消息(共 7 条)
6,208 次查看
Thank you very much, Kaoya!!! You are very kind!!
I has contacted NI company with the number you provided today.  So I will send my card to them, they will help me to check it.
Thanks for your source anyway.
0 项奖励
5 条消息(共 7 条)
6,199 次查看
my pleasure, anyway, if you get problem or any doubt, just call them and they'll give you suggestion or idea to solver your problem.
regards
0 项奖励
6 条消息(共 7 条)
6,196 次查看
你的卡在MAX裡面自檢pass嗎?建議:不要用ni卡上內部vcc作外部電路的vcc。
0 项奖励
7 条消息(共 7 条)
6,170 次查看
