The event structures lock the Front Panel (by default) if the code inside the event structure is being executed. To unlock the Front Panel during execution mode, follow the following steps:
1) Right Click on "Event Structure"
2) Left Click on "Edit Events Handeled By This Case..."
3) Uncheck the box at the bottom of the window that says "Lock front panel until the event case for this event completes".
