NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
用了报表工具包后生成EXE文件报错
您好,我以前生成EXE文件没有问题,当我装了OFFICES报表工具包后,生成EXE文件时会报错,如附件,请求解答,谢谢
LabVIEW已阻止程序生成时发生的命名冲突。无法复制重复文件名至相同目标。将文件重命名为程序生成过程的一部分以避免名称冲突。
以下文件被移至单独位置:
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append Control Image to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append Control Image to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append File to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append File to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append Horizontal Line to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append Horizontal Line to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append Hypertext Link Anchor to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append Hypertext Link Anchor to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append Image to Report (path).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append Image to Report (path).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append Image to Report (string).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append Image to Report (string).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append List to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append List to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append Numeric Table to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append Numeric Table to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append Report Text (num).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append Report Text (num).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append Report Text (str).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append Report Text (str).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append Text Table to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append Text Table to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Append User Formatted HTML to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Append User Formatted HTML to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Clear Report Text.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Clear Report Text.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Clear Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Clear Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Get Report Settings.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Get Report Settings.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Get Report Type.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Get Report Type.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Image in Header or Footer.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Image in Header or Footer.vi
E:\labview8.6\labview\labview\vi.lib\printing\ReportDocExtensions.llb\Indent Subsquent Report.vi
E:\labview8.6\labview\labview\vi.lib\printing\ReportDocExtensions.llb\HTML\Indent Subsquent Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\New Report Line.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\New Report Line.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\New Report Page.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\New Report Page.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\new report subVI.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\new report subVI.vi
E:\labview8.6\labview\labview\vi.lib\printing\ReportDocExtensions.llb\Outdent Subsquent Report.vi
E:\labview8.6\labview\labview\vi.lib\printing\ReportDocExtensions.llb\HTML\Outdent Subsquent Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Print Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Print Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Save Report to File.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Save Report to File.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Set Report Font.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Set Report Font.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Set Report Footer Text.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Set Report Footer Text.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Set Report Header Text.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Set Report Header Text.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Set Report Margins.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Set Report Margins.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Dispose Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\HTML\Dispose Report.vi
E:\labview8.6\labview\labview\vi.lib\printing\ReportDocExtensions.llb\Append image and delete if possible.vi
E:\labview8.6\labview\labview\vi.lib\printing\ReportDocExtensions.llb\Standard Report\Append image and delete if possible.vi
E:\labview8.6\labview\labview\vi.lib\printing\ReportDocExtensions.llb\Append Section Break to Report.vi
E:\labview8.6\labview\labview\vi.lib\printing\ReportDocExtensions.llb\Standard Report\Append Section Break to Report.vi
E:\labview8.6\labview\labview\vi.lib\printing\ReportDocExtensions.llb\CatchAndConvertInvalidImageTypes.vi
E:\labview8.6\labview\labview\vi.lib\printing\ReportDocExtensions.llb\Standard Report\CatchAndConvertInvalidImageTypes.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Append Control Image to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Append File to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Append Hypertext Link Anchor to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Append Image to Report (path).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Append Image to Report (string).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Append List to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Append Numeric Table to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Append Report Text (num).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Append Report Text (str).vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Append Text Table to Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Clear Report Text.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Clear Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Dispose Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Get Report Settings.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Get Report Type.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Image in Header or Footer.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\New Report Line.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\New Report Page.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\new report subVI.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Print Report.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Save Report to File.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Set Report Font.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Set Report Footer Text.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Set Report Header Text.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Set Report Margins.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Set Report Orientation.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Set Report Orientation.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Set Report Tab Width.vi
E:\labview8.6\labview\labview\vi.lib\Utility\NIReport.llb\Standard Report\Set Report Tab Width.vi
0 项奖励
1 条消息(共 5 条)
4,283 次查看
请求帮助,谢谢
0 项奖励
2 条消息(共 5 条)
4,280 次查看
下面是运行的报错
0 项奖励
3 条消息(共 5 条)
4,262 次查看
再顶,求解答,谢谢
0 项奖励
4 条消息(共 5 条)
4,227 次查看
好象是所调用文件的路径有冲突,将顶层文件打开重新保存一下看看
0 项奖励
5 条消息(共 5 条)
4,220 次查看
